RFC 9302 Locator/ID Separation Protocol (LISP) Map-Versioning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2022
This document describes the Locator/ID Separation Protocol (LISP) Map-Versioning mechanism, which provides in-packet information about Endpoint-ID-to-Routing-Locator (EID-to-RLOC) mappings used to encapsulate LISP data packets. This approach is based on associating a version number to EID-to-RLOC mappings and transporting such a version number in the LISP-specific header of LISP-encapsulated packets. LISP Map-Versioning is particularly useful to inform communicating Ingress Tunnel Routers (ITRs) and Egress Tunnel Routers (ETRs) about modifications of the mappings used to encapsulate packets. The mechanism is optional and transparent to implementations not supporting this feature, since in the LISP-specific header and in the Map Records, bits used for Map-Versioning can be safely ignored by ITRs and ETRs that do not support or do not want to use the mechanism. This document obsoletes RFC 6834, which is the initial experimental specifications of the mechanisms updated by this document.
rfc9302.pdf (189.24 Ko) Télécharger le fichier
hal-03907754 , version 1 (20-12-2022)
  • HAL Id : hal-03907754 , version 1
Luigi Iannone, Damien Saucez, Olivier Bonaventure. RFC 9302 Locator/ID Separation Protocol (LISP) Map-Versioning. 2022. ⟨hal-03907754⟩
34 Consultations
10 Téléchargements
