An Integro-differential-delay Operator Approach to Transformations of Linear Differential Time-delay Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we further develop the study of rings of integro-differential-delay operators considered as noncommutative polynomial algebras satisfying standard calculus identities. Within the algebraic analysis approach, we show that transformations and reductions of linear differential time-delay systems can be interpreted as homomorphisms and isomorphisms of finitely presented left modules over an algebra of integro-differential-delay operators. In particular, we show how Fiagbedzi-Pearson's transformation can be found again and generalized. This transformation maps the solutions of a first-order differential linear system with state and input delays to the solutions of a purely state-space linear system. Fiagbedzi-Pearson's transformation reduces to the well-known Artstein's reduction when the system has no state delay and yields an isomorphism of the solution spaces.
Integro-diff-delay-final-reduced_corrected.pdf (262.91 Ko) Télécharger le fichier
hal-03908561 , version 1 (20-12-2022)
Alban Quadrat. An Integro-differential-delay Operator Approach to Transformations of Linear Differential Time-delay Systems. SSSC 2022 - 8th IFAC Symposium on System Structure and Control, Sep 2022, Montréal, Canada. ⟨10.1016/j.ifacol.2022.11.301⟩. ⟨hal-03908561⟩
31 Consultations
27 Téléchargements
