Parallel kinetic schemes for conservation laws, with large time steps - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail (Preprint/Prepublication) Année : 2022
We propose a new parallel Discontinuous Galerkin method for the approximation of hyperbolic systems of conservation laws. The method remains stable with large time steps, while keeping the complexity of an explicit scheme: it does not require the assembly and resolution of large linear systems for the time iterations. The approach is based on a kinetic representation of the system of conservation laws previously investigated by the authors. In this paper, the approach is extended with a subdomain strategy that improves the parallel scaling of the method on computers with distributed memory.
Gerhard_Helluy_Michel-Dansac_Weber.pdf (10.2 Mo) Télécharger le fichier
Licence : CC BY NC ND - Paternité - Pas d'utilisation commerciale - Pas de modification
hal-03910307 , version 1 (22-12-2022)
hal-03910307 , version 2 (24-02-2024)
  • HAL Id : hal-03910307 , version 1
Pierre Gerhard, Philippe Helluy, Victor Michel-Dansac, Bruno Weber. Parallel kinetic schemes for conservation laws, with large time steps. 2022. ⟨hal-03910307v1⟩
90 Consultations
32 Téléchargements
