Convergence analysis of time-domain PMLs for 2D electromagnetic wave propagation in dispersive waveguides - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Mathematical Modelling and Numerical Analysis Année : 2023
This work is dedicated to the analysis of generalized perfectly matched layers (PMLs) for 2D electromagnetic wave propagation in dispersive waveguides. Under quite general assumptions on frequency-dependent dielectric permittivity and magnetic permeability we prove convergence estimates in homogeneous waveguides and show that the PML error decreases exponentially with respect to the absorption parameter and the length of the absorbing layer. The optimality of this error estimate is studied both numerically and analytically. Finally, we demonstrate that in the case when the waveguide contains a heterogeneity supported away from the absorbing layer, instabilities may occur, even in the case of the non-dispersive media. Our findings are illustrated by numerical experiments.
mainreport_to_submit.pdf (1.99 Mo) Télécharger le fichier
erratum.pdf (24.11 Ko) Télécharger le fichier
hal-03910611 , version 1 (22-12-2022)
Paternité
  • HAL Id : hal-03910611 , version 1
Eliane Bécache, Maryna Kachanovska, Markus Wess. Convergence analysis of time-domain PMLs for 2D electromagnetic wave propagation in dispersive waveguides. ESAIM: Mathematical Modelling and Numerical Analysis, 2023. ⟨hal-03910611⟩
128 Consultations
70 Téléchargements
