Estimation of extreme quantiles from heavy-tailed distributions with neural networks - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2022
New parametrizations for neural networks are proposed in order to estimate extreme quantiles in both non-conditional and conditional heavy-tailed settings. All proposed neural network estimators feature a bias correction based on an extension of the usual second-order condition to an arbitrary order. The convergence rate of the uniform error between extreme log-quantiles and their neural network approximation is established. The finite sample performances of the non-conditional neural network estimator are compared to other bias-reduced extreme-value competitors on simulated data. It is shown that our method outperforms them in difficult heavy-tailed situations where other estimators almost all fail. The source code is available at github. Finally, conditional neural network estimators are implemented to investigate the behavior of extreme rainfalls as functions of their geographical location in the southern part of France.
No file
Dates and versions
hal-03910645 , version 1 (22-12-2022)
Identifiers
  • HAL Id : hal-03910645 , version 1
Cite
Michaël Allouche, Stéphane Girard, Emmanuel Gobet. Estimation of extreme quantiles from heavy-tailed distributions with neural networks. CMStatistics 2022 - 15th International Conference of the ERCIM WG on Computational and Methodological Statistics, Dec 2022, London, United Kingdom. ⟨hal-03910645⟩
30 View
0 Download
Share
