On Tail Decay Rate Estimation of Loss Function Distributions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Machine Learning Research Année : 2022
The study of loss-function distributions is critical to characterize a model’s behaviour on a given machine-learning problem. While model quality is commonly measured by the average loss assessed on a testing set, this quantity does not ascertain the existence of the mean of the loss distribution. Conversely, the existence of a distribution’s statistical moments can be verified by examining the thickness of its tails. Cross-validation schemes determine a family of testing loss distributions conditioned on the training sets. By marginalizing across training sets, we can recover the overall (marginal) loss distribution, whose tail-shape we aim to estimate. Small sample-sizes diminish the reliability and efficiency of classical tail-estimation methods like Peaks-Over-Threshold, and we demonstrate that this effect is notably significant when estimating tails of marginal distributions composed of conditional distributions with substantial tail location variability. We mitigate this problem by utilizing a result we prove: under certain conditions, the marginal-distribution’s tail-shape parameter is the maximum tail-shape parameter across the conditional distributions underlying the marginal. We label the resulting approach as ‘cross-tail estimation (CTE)’. We test CTE in a series of experiments on simulated and real data, showing the improved robustness and quality of tail estimation as compared to classical approaches.
JMLR_Camera_Ready_.pdf (6.09 Mo) Télécharger le fichier
hal-03911884 , version 1 (23-12-2022)
hal-03911884 , version 2 (23-12-2023)
  • HAL Id : hal-03911884 , version 2
Etrit Haxholli, Marco Lorenzi. On Tail Decay Rate Estimation of Loss Function Distributions. Journal of Machine Learning Research, In press. ⟨hal-03911884v2⟩
158 Consultations
98 Téléchargements
