Reduced Representation of Deformation Fields for Effective Non-rigid Shape Matching - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this work we present a novel approach for computing correspondences between non-rigid objects, by exploiting a reduced representation of deformation fields. Different from existing works that represent deformation fields by training a generalpurpose neural network, we advocate for an approximation based on mesh-free methods. By letting the network learn deformation parameters at a sparse set of positions in space (nodes), we reconstruct the continuous deformation field in a closed-form with guaranteed smoothness. With this reduction in degrees of freedom, we show significant improvement in terms of data-efficiency thus enabling limited supervision. Furthermore, our approximation provides direct access to first-order derivatives of deformation fields, which facilitates enforcing desirable regularization effectively. Our resulting model has high expressive power and is able to capture complex deformations. We illustrate its effectiveness through stateof-the-art results across multiple deformable shape matching benchmarks. Our code and data are publicly available at: https://github.com/Sentient07/ DeformationBasis.
main.pdf (6.67 Mo) Télécharger le fichier
hal-03912305 , version 1 (23-12-2022)
  • HAL Id : hal-03912305 , version 1
Ramana Sundararaman, Riccardo Marin, Emanuele Rodola, Maks Ovsjanikov. Reduced Representation of Deformation Fields for Effective Non-rigid Shape Matching. NeurIPS 2022 - 36th Conference on Neural Information Processing Systems, Nov 2022, New Orleans, United States. ⟨hal-03912305⟩
76 Consultations
18 Téléchargements
