Insight into numerical solutions of static large deflection of general planar beams for Compliant Mechanisms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mechanism and Machine Theory Année : 2022
We formulated the large beam-deflection problem as a general nonlinear BVP. • We reviewed the commonly used methods for modeling beam deflection in CMs. • We introduced efficient numerical methods to solve beam deflection problems. • We provided comments and analysis about all the mentioned methods.
MMT.pdf (1.66 Mo) Télécharger le fichier
hal-03912829 , version 1 (26-12-2022)
Ke Wu, Gang Zheng. Insight into numerical solutions of static large deflection of general planar beams for Compliant Mechanisms. Mechanism and Machine Theory, 2022, 172, pp.104757. ⟨10.1016/j.mechmachtheory.2022.104757⟩. ⟨hal-03912829⟩
47 Consultations
68 Téléchargements
