Solutions to large beam-deflection problems by Taylor series and Padé approximant for compliant mechanisms
Highlights Solutions to Large Beam-deflection Problems by Taylor series and Padé approximant for Compliant Mechanisms Ke Wu,Gang Zheng • We solved large beam-deflection problems by Taylor series method. • We solved large beam-deflection problems by Padé approximant. • We provided convergence analysis on the 2 methods. • We proved the feasibility of modeling CMs using the 2 methods.
