Source and metric estimation in the eikonal equation using optimization on a manifold - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
We address the estimation of the source(s) location in the eikonal equation on a Riemann surface, as well as the determination of the metric when it depends on a few parameters. The available observations are the arrival times or are obtained indirectly from the arrival times by an observation operator, this frame is intended to describe electro-cardiographic imaging. The sensitivity of the arrival times is computed from Log x the log map wrt to the source x on the surface. The Log x map is approximated by solving an elliptic vectorial equation, using the Vector Heat Method. The L 2-error function between the model predictions and the observations is minimized using Gauss-Newton optimization on the Riemann surface. This allows to obtain fast convergence. We present numerical results, where coefficients describing the metric are also recovered like anisotropy and global orientation.
papier_IPI_soumis.pdf (1.01 Mo) Télécharger le fichier
hal-03475139 , version 1 (10-12-2021)
  • HAL Id : hal-03475139 , version 1
Jérôme Fehrenbach, Lisl Weynans. Source and metric estimation in the eikonal equation using optimization on a manifold. 2021. ⟨hal-03475139⟩
158 Consultations
143 Téléchargements
