Reversible Computing in Debugging of Erlang Programs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IT Professional Année : 2022
Ulrik Schultz
Irek Ulidowski
Reversible computation is a computing paradigm where execution can progress backwards as well as in the usual, forward direction. It has found applications in many areas of computer science, such as circuit design, programming languages, simulation, modelling of biochemical reactions, debugging and robotics. In this article, we give an overview of reversible computation focusing on its use in reversible debugging of concurrent programs written in the Erlang programming language.
Mots clés
main-debugging.pdf (454.29 Ko) Télécharger le fichier
Licence : Copyright (Tous droits réservés)
hal-03917301 , version 1 (01-01-2023)
Ivan Lanese, Ulrik Schultz, Irek Ulidowski. Reversible Computing in Debugging of Erlang Programs. IT Professional, 2022, 24 (1), pp.74-80. ⟨10.1109/MITP.2021.3117920⟩. ⟨hal-03917301⟩
24 Consultations
62 Téléchargements
