Semantics of Probabilistic Programs using s-Finite Kernels in Coq - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Probabilistic programming languages are used to write probabilistic models to make probabilistic inferences. A number of rigorous semantics have recently been proposed that are now available to carry out formal verification of probabilistic programs. In this paper, we extend an existing formalization of measure and integration theory with s-finite kernels, a mathematical structure to interpret typing judgments in the semantics of a probabilistic programming language. The resulting library makes it possible to reason formally about transformations of probabilistic programs and their execution.
poplws23cppmain-p61-p-b400dabdc2-62273-submitted.pdf (726.03 Ko) Télécharger le fichier
hal-03917948 , version 1 (02-01-2023)
Reynald Affeldt, Cyril Cohen, Ayumu Saito. Semantics of Probabilistic Programs using s-Finite Kernels in Coq. CPP 2023 - Certified Programs and Proofs, Jan 2023, Boston, United States. ⟨10.1145/3573105.3575691⟩. ⟨hal-03917948⟩
116 Consultations
272 Téléchargements
