Clinically Meaningful <scp>Magnetic Resonance</scp> Endpoints Sensitive to Preataxic Spinocerebellar Ataxia Types <scp>1</scp> and <scp>3</scp> - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Annals of Neurology Année : 2022
Clinically Meaningful Magnetic Resonance Endpoints Sensitive to Preataxic Spinocerebellar Ataxia Types 1 and 3
S H Subramony
Gülin Öz
Objective: This study was undertaken to identify magnetic resonance (MR) metrics that are most sensitive to early changes in the brain in spinocerebellar ataxia type 1 (SCA1) and type 3 (SCA3) using an advanced multimodal MR imaging (MRI) protocol in the multisite trial setting. Methods: SCA1 or SCA3 mutation carriers and controls (n = 107) underwent MR scanning in the US-European READISCA study to obtain structural, diffusion MRI, and MR spectroscopy data using an advanced protocol at 3T. Morphometric, microstructural, and neurochemical metrics were analyzed blinded to diagnosis and compared between preataxic SCA (n = 11 SCA1, n = 28 SCA3), ataxic SCA (n = 14 SCA1, n = 37 SCA3), and control (n = 17) groups using nonparametric testing accounting for multiple comparisons. MR metrics that were most sensitive to preataxic abnormalities were identified using receiver operating characteristic (ROC) analyses.
Chandrasekaran_Annals of Neurology - 2022 - Clinically Meaningful Magnetic Resonance Endpoints Sensitive to Preataxic.pdf (3.07 Mo) Télécharger le fichier
hal-03917995 , version 1 (02-01-2023)
Jayashree Chandrasekaran, Emilien Petit, Young Woo Park, Sophie Tezenas Du Montcel, James M Joers, et al.. Clinically Meaningful Magnetic Resonance Endpoints Sensitive to Preataxic Spinocerebellar Ataxia Types 1 and 3. Annals of Neurology, 2022, ⟨10.1002/ana.26573⟩. ⟨hal-03917995⟩
65 Consultations
50 Téléchargements
