Data-driven wall models for Reynolds Averaged Navier-Stokes simulations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Heat and Fluid Flow Année : 2023
This article presents a data-based methodology to build Reynolds-Averaged Navier-Stokes (RANS) wall models for aerodynamic simulations at low Mach numbers. Like classical approaches, the model is based on nondimensional local quantities derived from the wall friction velocity u τ , the wall viscosity µ w , and the wall density ρ w. A fully-connected neural network approximates the relation u + = f (y + , p +). We consider reference data (obtained with RANS simulations based on fine meshes up to the wall) of attached turbulent flows at various Reynolds numbers over different geometries of bumps, covering a range of wall pressure gradients. After training the neural networks on a subset of the reference data, the paper assesses their ability to accurately recover data for unseen conditions on meshes that have been trimmed from the wall up to an interface height where the learned wall law is applied. The network's interpolation and extrapolation capabilities are quantified and carefully examined. Overall, when tested within its interpolation and extrapolation capabilities, the neural network model shows good robustness and accuracy. The global error on the skin friction coefficient is a few percent and behaves consistently over all the considered test cases.
IJHFF.pdf (1.35 Mo) Télécharger le fichier
hal-03918157 , version 1 (02-01-2023)
Michele Romanelli, Samir Beneddine, Ivan Mary, Heloise Beaugendre, Michel Bergmann, et al.. Data-driven wall models for Reynolds Averaged Navier-Stokes simulations. International Journal of Heat and Fluid Flow, 2023, 99, pp.109097. ⟨10.1016/j.ijheatfluidflow.2022.109097⟩. ⟨hal-03918157⟩
35 Consultations
77 Téléchargements
