Four functional profiles for fibre and mucin metabolism in the human gut microbiome - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Microbiome Année : 2023
Background With the emergence of metagenomic data, multiple links between the gut microbiome and the host health have been shown. Deciphering these complex interactions require evolved analysis methods focusing on the microbial ecosystem functions. Despite the fact that host or diet-derived fibres are the most abundant nutrients available in the gut, the presence of distinct functional traits regarding fibre and mucin hydrolysis, fermentation and hydrogenotrophic processes has never been investigated. Results After manually selecting 91 KEGG orthologies and 33 glycoside hydrolases further aggregated in 101 functional descriptors representative of fibre and mucin degradation pathways in the gut microbiome, we used non-negative matrix factorization to mine metagenomic datasets. Four distinct metabolic profiles were further identified on a training set of 1153 samples and thoroughly validated on a large database of 2571 unseen samples from 5 external metagenomic cohorts. Profiles 1 and 2 are the main contributors to the fibre-degradation-related metagenome: they present contrasted involvement in fibre degradation and sugar metabolism and are differentially linked to dysbiosis, metabolic disease and inflammation. Profile 1 takes over Profile 2 inhealthy samples, and unbalance of these profiles characterize dysbiotic samples. Furthermore, high fibre diet favours a healthy balance between Profiles 1 and Profile 2. Profile 3 takes over Profile 2 during Crohn’s disease, inducing functional reorientations towards unusual metabolism such as fucose and H2S degradation or propionate, acetone and butanediol production. Profile 4 gathers under-represented functions, like methanogenesis. Two taxonomic makes up of the profiles were investigated, using either the covariation of 203 prevalent genomes or metagenomic species, both providing consistent results in line with their functional characteristics. This taxonomic characterization showed that Profiles 1 and 2 were respectively mainly composed of bacteria from the phyla Bacteroidetes and Firmicutes while Profile 3 is representative of Proteobacteria and Profile 4 of methanogens. Conclusions Integrating anaerobic microbiology knowledge with statistical learning can narrow down the metagenomic analysis to investigate functional profiles. Applying this approach to fibre degradation in the gut ended with 4 distinct functional profiles that can be easily monitored as markers of diet, dysbiosis, inflammation and disease.
s40168-023-01667-y.pdf (11.64 Mo) Télécharger le fichier
Licence : CC BY - Paternité
hal-03918193 , version 1 (02-01-2023)
hal-03918193 , version 2 (20-10-2023)
Paternité
Simon Labarthe, Sandra Plancade, Sébastien Raguideau, Florian Plaza Oñate, Emmanuelle Le Chatelier, et al.. Four functional profiles for fibre and mucin metabolism in the human gut microbiome. Microbiome, 2023, 11 (1), pp.231. ⟨10.1186/s40168-023-01667-y⟩. ⟨hal-03918193v2⟩
335 Consultations
161 Téléchargements
