Functional and Timing Implications of Transient Faults in Critical Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Embedded systems in critical domains, such as automotive, aviation, space domains, are often required to guarantee both functional and temporal correctness. Considering transient faults, fault analysis and mitigation approaches are implemented at various levels of the system design, in order to maintain the functional correctness. However, transient faults and their mitigation methods have a timing impact, which can affect the temporal correctness of the system. In this work, we expose the functional and the timing implications of transient faults for critical systems. More precisely, we initially highlight the timing effect of transient faults occurring in the combinational and sequential logic of a processor. Furthermore, we propose a full stack vulnerability analysis that drives the design of selective hardware-based mitigation for real-time applications. Last, we study the timing impact of software-based reliability mitigation methods applied in a COTS GPU, using a fault tolerant middleware.
IOLTS22_special_real_time-4.pdf (3.39 Mo) Télécharger le fichier
hal-03923506 , version 1 (04-01-2023)
  • HAL Id : hal-03923506 , version 1
Angeliki Kritikakou, Panagiota Nikolaou, Ivan Rodriguez-Ferrandez, Joseph Paturel, Leonidas Kosmidis, et al.. Functional and Timing Implications of Transient Faults in Critical Systems. IOLTS 2022 – 28th IEEE International Symposium on OnLine Testing and Robust System Design, Sep 2022, Torino, Italy. pp.1-10. ⟨hal-03923506⟩
16 Consultations
84 Téléchargements
