Reduced structural flexibility of eplet amino acids in HLA proteins - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2022
The proteins encoded in the HLA (Human Leukocyte Antigen) system are largely responsible for the compatibility in organ transplants. To date, the molecular determinants involved in recognizing HLA antigens by recipient antibodies are unknown. Here we explore flexibility as a potential determinant. For this purpose, we compare in terms of N-RMSF (Normalized Root Mean Square Fluctuation) amino acids labeled as confirmed eplets (regions defined around polymorphic amino acids) against amino acids that have not been reported as eplets. We found that eplet amino acids tend to be less flexible than non-eplet amino acids, which would indicate that the antibodies would have a preference for binding with less mobile regions.
ECCB_2022.pdf (668.43 Ko) Télécharger le fichier
hal-03924018 , version 1 (05-01-2023)
  • HAL Id : hal-03924018 , version 1
Diego Amaya-Ramirez, Romain Lhotte, Magali Devriese, Constantin Hays, Jean-Luc Taupin, et al.. Reduced structural flexibility of eplet amino acids in HLA proteins. ECCB 2022 21st European Conference on Computational Biology Planetary Health and Biodiversity, Sep 2022, Barcelona, Spain. ⟨hal-03924018⟩
44 Consultations
31 Téléchargements
