Susceptibility synthesis of arbitrary shaped metasurfaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physical Review B Année : 2022
Visual perception relies on light scattering at the object's surface in the direction of observation. By engineering the surface scattering properties, it is possible to realize arbitrary visual percept. Here, we address theoretically this problem of electromagnetic field transition conditions at conformal interfaces to achieve surface topography-dependent transmitted and reflected fields. Our analysis, supported by two-and three-dimensional finite element simulations, provides a solid theoretical framework to design metasurfaces for cloaking, wearable optics and next generation of freeform imaging systems.
PRL-CGSTCs.pdf (3.77 Mo) Télécharger le fichier
hal-03924790 , version 1 (05-01-2023)
N. Lebbe, S. Lanteri, S. Golla, P. Genevet. Susceptibility synthesis of arbitrary shaped metasurfaces. Physical Review B, 2022, 106 (3), pp.035110. ⟨10.1103/PhysRevB.106.035110⟩. ⟨hal-03924790⟩
41 Consultations
53 Téléchargements
