Revisiting the limiting amplitude principle for the wave equation with variable coefficients - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The limiting amplitude principle is a well-known result connecting the solution of the Helmholtz equation with the large-time behavior of timedependent wave equations with a source term which is periodic in time. Motivated by numerical analysis of time-domain methods for stationary scattering problems in heterogeneous media, we quantify the solution convergence of such time-dependent wave equation towards the stationary solution, under some assumptions on the coefficients and the source term. We also generalise the formulation of the limiting amplitude principle to the one-dimensional setting where the classical statement of the principle is known to be violated.
waves-ponomarev.pdf (196.58 Ko) Télécharger le fichier
hal-03925536 , version 1 (05-01-2023)
  • HAL Id : hal-03925536 , version 1
Anton Arnold, Sjoerd Geevers, Ilaria Perugia, Dmitry Ponomarev. Revisiting the limiting amplitude principle for the wave equation with variable coefficients. Waves 2022, Jul 2022, Palaiseau, France. ⟨hal-03925536⟩
25 Consultations
32 Téléchargements
