Abstract Interpretation-Based Feature Importance for SVMs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2022
We propose a symbolic representation for support vector machines (SVMs) by means of abstract interpretation, a well-known and successful technique for designing and implementing static program analyses. We leverage this abstraction in two ways: (1) to enhance the interpretability of SVMs by deriving a novel feature importance measure, called abstract feature importance (AFI), that does not depend in any way on a given dataset of the accuracy of the SVM and is very fast to compute, and (2) for verifying stability, notably individual fairness, of SVMs and producing concrete counterexamples when the verification fails. We implemented our approach and we empirically demonstrated its effectiveness on SVMs based on linear and nonlinear (polynomial and radial basis function) kernels. Our experimental results show that, independently of the accuracy of the SVM, our AFI measure correlates much more strongly with the stability of the SVM to feature perturbations than feature importance measures widely available in machine learning software such as permutation feature importance. It thus gives better insight into the trustworthiness of SVMs.
afi.pdf (330.79 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-03926237 , version 1 (06-01-2023)
  • HAL Id : hal-03926237 , version 1
Abhinandan Pal, Francesco Ranzato, Caterina Urban, Marco Zanella. Abstract Interpretation-Based Feature Importance for SVMs. IIIT Kalyani; University of Padova; Inria Paris; École Normale Supérieure. 2022. ⟨hal-03926237⟩
14 Consultations
21 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
