Abstract Interpretation-Based Data Leakage Static Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2022
Data leakage is a well-known problem in machine learning. Data leakage occurs when information from outside the training dataset is used to create a model. This phenomenon renders a model excessively optimistic or even useless in the real world since the model tends to leverage greatly on the unfairly acquired information. To date, detection of data leakages occurs post-mortem using run-time methods. However, due to the insidious nature of data leakage, it may not be apparent to a data scientist that a data leakage has occurred in the first place. For this reason, it is advantageous to detect data leakages as early as possible in the development life cycle. In this paper, we propose a novel static analysis to detect several instances of data leakages during development time. We define our analysis using the framework of abstract interpretation: we define a concrete semantics that is sound and complete, from which we derive a sound and computable abstract semantics. We implement our static analysis inside the open-source NBLyzer static analysis framework and demonstrate its utility by evaluating its performance and precision on over 2000 Kaggle competition notebooks.
main.pdf (1.16 Mo) Télécharger le fichier
hal-03926245 , version 1 (09-01-2023)
hal-03926245 , version 2 (23-04-2024)
  • HAL Id : hal-03926245 , version 1
Filip Drobnjaković, Pavle Subotić, Caterina Urban. Abstract Interpretation-Based Data Leakage Static Analysis. Microsoft Research; Inria Paris; École Normale Supérieure. 2022. ⟨hal-03926245v1⟩
32 Consultations
39 Téléchargements
