Exhaustive synthesis of microwave circuits with frequency dependent couplings - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The synthesis of bandpass microwave filters is based on the use of equivalent circuit models made of coupled resonators. These couplings are usually supposed to be independent of the frequency. We present in this paper a circuit model including possibly frequency varying couplings. After presenting some of its properties we consider the associated synthesis problem and show how techniques such as Groebner basis computation and Schur analysis based extraction techniques can be used to solve the latter exhaustively.
MTNS22.pdf (266.57 Ko) Télécharger le fichier
hal-03926246 , version 1 (06-01-2023)
  • HAL Id : hal-03926246 , version 1
Martine Olivi, Fabien Seyfert, Ke-Li Wu, Yan Zhang. Exhaustive synthesis of microwave circuits with frequency dependent couplings. MTNS 2022 - 25th International Symposium on Mathematical Theory of Networks and Systems, Sep 2022, Bayreuth, Germany. ⟨hal-03926246⟩
27 Consultations
29 Téléchargements
