Towards local testability for quantum coding - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Quantum Année : 2022
We introduce the hemicubic codes, a family of quantum codes obtained by associating qubits with the p-faces of the n-cube (for n > p) and stabilizer constraints with faces of dimension (p ± 1). The quantum code obtained by identifying antipodal faces of the resulting complex encodes one logical qubit into N = 2 n−p−1 n p physical qubits and displays local testability with a soundness of Ω(1/ log(N)) beating the current state-of-the-art of 1/ log 2 (N) due to Hastings. We exploit this local testability to devise an efficient decoding algorithm that corrects arbitrary errors of size less than the minimum distance, up to polylog factors. We then extend this code family by considering the quotient of the n-cube by arbitrary linear classical codes of length n. We establish the parameters of these generalized hemicubic codes. Interestingly, if the soundness of the hemicubic code could be shown to be constant, similarly to the ordinary n-cube, then the generalized hemicubic codes could yield quantum locally testable codes of length not exceeding an exponential or even polynomial function of the code dimension. 1
1911.03069-6.pdf (837.1 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-03926985 , version 1 (06-01-2023)
Anthony Leverrier, Vivien Londe, Gilles Zémor. Towards local testability for quantum coding. Quantum, 2022, 6, pp.661. ⟨10.22331/q-2022-02-24-661⟩. ⟨hal-03926985⟩
21 Consultations
163 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
