Discrete moments models for Vlasov equations with non constant strong magnetic limit - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Comptes Rendus. Mécanique Année : 2023
We describe the structure of an original application of the method of moments to the Vlasov-Poisson system with non constant strong magnetic field in three dimensions of space. Using basis functions which are aligned with the magnetic field, one obtains a Friedrichs system where the kernel of the singular part is made explicit. A projection of the original model on this kernel yields what we call the reduced model. Basic numerical tests of the field illustrate the accuracy of our implementation. A new generating formula for Laguerre polynomials is obtained in the appendix as a byproduct of the analysis.
main-05-12-2022.pdf (2.23 Mo) Télécharger le fichier
hal-03927990 , version 1 (06-01-2023)
  • HAL Id : hal-03927990 , version 1
Frédérique Charles, Bruno Després, Ruiyang Dai, Sever Adrian Hirstoaga. Discrete moments models for Vlasov equations with non constant strong magnetic limit. Comptes Rendus. Mécanique, 2023, 351 (S1), pp.1-23. ⟨hal-03927990⟩
145 Consultations
140 Téléchargements
