Thesaurus Enrichment via Coordination Extraction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We advance a method of thesaurus enrichment, based on the extraction of coordinations in a domain-related corpus. Our hypothesis is that there is a semantic homogeneity between the conjuncts located in a coordination. We conducted an experiment that allowed us to evaluate the effectiveness of our method. This experiment aims to enrich the concept hierarchy of a French agricultural thesaurus named French Crop Usage (FCU), thanks to the texts of the Plant Health Bulletins (PHB). The FCU thesaurus is published on the Web using the SKOS model.
MTSR2022_paper_1863.pdf (736.24 Ko) Télécharger le fichier
Licence : CC BY NC SA - Paternité - Pas d'utilisation commerciale - Partage selon les Conditions Initiales
hal-03933526 , version 1 (10-01-2023)
  • HAL Id : hal-03933526 , version 1
Anna Chepaikina, Robert Bossy, Catherine Roussey, Stephan Bernard. Thesaurus Enrichment via Coordination Extraction. 16th International Conference on Metadata and Semantics Research (MTSR 2022), Nov 2022, London, United Kingdom. ⟨hal-03933526⟩
51 Consultations
64 Téléchargements
