Formal proofs applied to system models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Évelyne Contejean
Andrei Samokish
  • Fonction : Auteur
  • PersonId : 1214913
Usually, the description of nuclear equipment by the FMEA (Failure Mode and Effects Analysis) method can be of considerable length (up to 5,000 lines); on the other hand, the number of rules used for the verification of this equipment is small. In addition, upstream, there is the question of trust in the tools that generate these descriptions for complex equipment, that is to say, made up of several thousand objects (requirements, functions, interfaces, behaviors).
jfla23_paper_9404.pdf (525.55 Ko) Télécharger le fichier
hal-03936894 , version 1 (12-01-2023)
hal-03936894 , version 2 (25-01-2023)
  • HAL Id : hal-03936894 , version 1
Évelyne Contejean, Andrei Samokish. Formal proofs applied to system models. JFLA 2023 - 34èmes Journées Francophones des Langages Applicatifs, Jan 2023, Praz-sur-Arly, France. pp.160-172. ⟨hal-03936894v1⟩
96 Consultations
131 Téléchargements
