A posteriori error estimates for mixed finite element discretizations of the Neutron Diffusion equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
We analyse $a\ posteriori$ error estimates for the discretization of the neutron diffusion equations with mixed finite elements. We provide guaranteed and locally efficient estimators on a base block equation, the one-group neutron diffusion equation. We pay particular attention to AMR strategies on Cartesian meshes, since such structures are common for nuclear reactor core applications. We exhibit a robust marker strategy for this specific constraint, the $direction\ marker$ strategy. The approach is further extended to a Domain Decomposition Method, the so-called DD+$L^2$ jumps method, as well as to the multigroup neutron diffusion equation.
CiDM20_submission.pdf (2.45 Mo) Télécharger le fichier
hal-03936904 , version 1 (08-07-2020)
hal-03936904 , version 2 (12-01-2023)
Patrick Ciarlet, Minh Hieu Do, François Madiot. A posteriori error estimates for mixed finite element discretizations of the Neutron Diffusion equations. 2020. ⟨hal-03936904v1⟩
427 Consultations
259 Téléchargements
