Periodic and Quasi-Periodic Orbits near Close Planetary Moons - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Guidance, Control, and Dynamics Année : 2023
Upcoming missions toward remote planetary moons will fly in chaotic dynamic environments that are significantly perturbed by the oblateness of the host planet. Such a dominant perturbation is often neglected when designing spacecraft trajectories in planetary moon systems. This paper introduces a new time-periodic set of equations of motion that is based on the analytical solution of the zonal equatorial problem and better describes the dynamic evolution of a spacecraft subject to the gravitational attraction of a moon and its oblate host planet. Such a system, hereby referred to as the zonal hill problem, remains populated by resonant periodic orbits and families of two-dimensional quasi-periodic invariant tori that are calculated by means of numerical continuation procedures. The resulting periodic and quasi-periodic trajectories are investigated for the trajectory design of future planetary moons explorers.
main.pdf (2.42 Mo) Télécharger le fichier
hal-03937917 , version 1 (13-01-2023)
Nicola Baresi, Lamberto Dell'Elce. Periodic and Quasi-Periodic Orbits near Close Planetary Moons. Journal of Guidance, Control, and Dynamics, In press, pp.1-15. ⟨10.2514/1.G007221⟩. ⟨hal-03937917⟩
55 Consultations
65 Téléchargements
