Deriving formal semantic representations from dependency structures - Extended Abstract - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Philippe de Groote
We outline the essentials of a formal semantic theory for dependency grammars. This theory, which derives from Montague’s semantics, is fully compositional, allows for a treatment of quantification, and is robust in the sense that it supports the interpretation of partial dependency structures.
PreProc.pdf (109.85 Ko) Télécharger le fichier
hal-03940888 , version 1 (16-01-2023)
Paternité
  • HAL Id : hal-03940888 , version 1
Philippe de Groote. Deriving formal semantic representations from dependency structures - Extended Abstract. LENLS19 - Logic and Engineering of Natural Language Semantics 19, Nov 2022, Tokyo, Japan. pp.87-91. ⟨hal-03940888⟩
58 Consultations
78 Téléchargements
