Simulating Feature Structures with Simple Types
Feature structures have been several times considered to enrich categorial grammars in order to build fine-grained grammars. Most attempts to unify both frameworks either model categorial types as feature structures or add feature structures on top of categorial types. We pursue a different approach: using feature structure as categorial atomic types. In this article, we present a procedure to create, from a simplified HPSG grammar, an equivalent abstract categorial grammar (ACG). We represent a feature structure by the enumeration of its totally well-typed upper bounds, so that unification can be simulated as intersection. We implement this idea as a meta-ACG preprocessor.
Origin : Publisher files allowed on an open archive
Licence : CC BY - Attribution
