Event-triggered control for discrete-time piecewise affine systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Systems and Control Letters Année : 2022
This work addresses the event-triggered control (ETC) of discrete-time piecewise affine systems. We propose a method to design a triggering strategy relying on an implicit representation of piecewise affine systems. Thanks to this implicit representation based on ramp functions, we propose a partition-dependent piecewise quadratic functions to define the trigger criterion and use a piecewise quadratic Lyapunov function candidate to derive conditions to certify the global exponential stability of the origin under the ETC strategy. Since the stability conditions can be expressed as linear matrix inequalities constraints, we propose a convex optimization solution to design the triggering function parameters and to compute the Lyapunov function to ensure the closed-loop stability and a reduction on the control updates. The approach is illustrated by numerical examples.
Automatique
PWA_SCL_vrev.pdf (397.56 Ko) Télécharger le fichier
hal-03946021 , version 1 (18-01-2023)
Leonardo Groff, João Gomes da Silva, Giorgio Valmorbida. Event-triggered control for discrete-time piecewise affine systems. Systems and Control Letters, 2022, 170, pp.105394. ⟨10.1016/j.sysconle.2022.105394⟩. ⟨hal-03946021⟩
28 Consultations
31 Téléchargements
