Improved Differential-Linear Attacks with Applications to ARX Ciphers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Cryptology Année : 2022
We present several improvements to the framework of differential-linear attacks with a special focus on ARX ciphers. As a demonstration of their impact, we apply them to Chaskey and ChaCha and we are able to significantly improve upon the best attacks published so far.
Advanced_Differential_Linear_Attacks__joc_.pdf (4.71 Mo) Télécharger le fichier
hal-03947756 , version 1 (19-01-2023)
Christof Beierle, Marek Broll, Federico Canale, Nicolas David, Antonio Flórez-Gutiérrez, et al.. Improved Differential-Linear Attacks with Applications to ARX Ciphers. Journal of Cryptology, 2022, 35 (4), pp.29. ⟨10.1007/s00145-022-09437-z⟩. ⟨hal-03947756⟩
Collections
INRIA INRIA2
20 Consultations
81 Téléchargements
