Parallel approximation of the exponential of Hermitian matrices
Approximation parallèle de l'exponentielle de matrices Hermitiennes
We are interested in the approximation of the exponential function on a real interval by a particular rational function (inverse of a polynomial). Using the
partial fraction decomposition of this rational function, we build an algorithm for computing the exponential of a matrix that is adapted to parallel computing. The performances of this parallel algorithm, both in accuracy and in computing time, are quantitatively analyzed.
HKPS.pdf (1.4 Mo)
Télécharger le fichier
Article_HKPS.zip (2.2 Mo)
