Optimal Control of Coffee Berry Borers: Synergy Between Bio-insecticide and Traps - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Optimization Theory and Applications Année : 2023
The coffee berry borer (CBB), Hypothenemus hampei, is the most destructive insect pest affecting coffee plantations in most coffee-producing countries, hence causing major economic losses worldwide. The cryptic life cycle of CBB inside coffee berries makes their control extremely difficult. To tackle this problem, we use a dynamical model describing the plant–pest interactions during a cropping season, which includes a berry age structure to account for CBB preference for mature berries. We introduce two environmentally friendly control methods, consisting in applying a bio-insecticide to reduce berry infestation and in trapping the colonising CBB. Our objective is to maximise the profit generated by the harvest of healthy coffee berries, while minimising the CBB population for the next cropping season. The existence of an optimal control strategy is provided, and necessary optimality conditions are established. Finally, the optimal control problem is solved numerically and simulations are provided. They show that combining the two control methods is a cost-effective strategy to protect coffee berries from CBB infestation.
CBB-Berries_preprint_2022.pdf (855.54 Ko) Télécharger le fichier
Licence : CC BY - Paternité
Commentaire : Preprint
hal-03954863 , version 1 (24-01-2023)
Copyright (Tous droits réservés)
Yves Fotso Fotso, Suzanne Touzeau, Frédéric Grognard, Berge Tsanou, Samuel Bowong. Optimal Control of Coffee Berry Borers: Synergy Between Bio-insecticide and Traps. Journal of Optimization Theory and Applications, 2023, 196 (3), pp.882-899. ⟨10.1007/s10957-022-02151-7⟩. ⟨hal-03954863⟩
66 Consultations
107 Téléchargements
