Survey of Models and Architectures to Ensure Linked Data Access - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2023
Mobile Access to the Web of Data is currently a real challenge in developing countries, mainly characterized by limited Internet connectivity and high penetration of mobile devices with the limited resources (such as cache and memory). In this paper, we survey and compare proposed solutions (such as models and architectures) that could contribute to solving this problem of mobile access to the Web of Data with intermittent Internet access. These solutions are discussed in relation to the underlying network architectures and data models considered. We present a conceptual study of peer-to-peer solutions based on gossip protocols dedicated to design the connected overlay networks. In addition, we provide a detailed analysis of client-server and data replication systems generally designed to ensure the local availability of data on the system. We conclude with some recommendations to achieve a connected architecture that provides mobile contributors with local access to the Web of data.
MahamadouToureSurvey.pdf (350.96 Ko) Télécharger le fichier
hal-03956456 , version 1 (25-01-2023)
Paternité
  • HAL Id : hal-03956456 , version 1
Mahamadou Toure, Fabien Gandon, Kaladzavi Guidedi, Moussa Lo, Christophe Guéret. Survey of Models and Architectures to Ensure Linked Data Access. Inria & Université Côte d'Azur, CNRS, I3S. 2023, pp.23. ⟨hal-03956456⟩
55 Consultations
58 Téléchargements
