Stochastic approximation of eigenvectors and eigenvalues of the Q-symmetric expectation of a random matrix - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Communications in Statistics - Theory and Methods Année : 2024
We establish an almost sure convergence theorem of the stochasticapproximation process of Oja for estimating eigenvectors of theQ-symmetric expectation of a random matrix, under a correlationmodel between the incoming random matrices. This theorem gener-alizes previous theorems and extends them to the case where themetricQis unknown and estimated online in parallel. We apply it tostreaming principal component analysis of a random vectorZ, whena mini-batch of observations ofZis used at each step or all theobservations up to the current step. We deal with the case ofstreaming generalized canonical correlation analysis, with a metricestimated online in parallel.
Online estim EV Q-sym matrix 20220823.pdf (888.18 Ko) Télécharger le fichier
hal-03956687 , version 1 (25-01-2023)
Jean-Marie Monnez. Stochastic approximation of eigenvectors and eigenvalues of the Q-symmetric expectation of a random matrix. Communications in Statistics - Theory and Methods, 2024, 53 (5), pp.1669-1683. ⟨10.1080/03610926.2022.2107225⟩. ⟨hal-03956687⟩
47 Consultations
82 Téléchargements
