Harmonic analysis on the boundary of hyperbolic groups - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
In this paper we show that a Möbius-structure $\mathcal{M}$ of dimension $Q$ has a minimal Ahlfors-David constant. This shows that a Möbius space is uniformly $Q$-Ahlfors-David regular. In summary, many classical theorems of harmonic analysis on $\mathbb{R}^n$ admit a Möbius-invariant formulation in the context of Möbius-geometry. We use this observation to show that the Knapp-Stein operator $$ (I_d^\alpha u_d)(x) = \int \frac{u_d(y)}{d(x,y)^{Q - \alpha}} \, d\mu_d(y), \quad\quad (\, 0 < \alpha < \frac{Q}{2}\,) $$ is a continuous operator on the weighted $L^2$-space $L^2((\frac{d'}{d})^{\alpha} d\mu_d)$, with a norm independent of $d$ and $d'$. From here we construct a Sobolev space $\mathcal{H}^{-\alpha}_d$ on $s$-densities for a given $s$ as a function of $\alpha$. We would like to say that the construction is topologically independent of the metric $d$. In this paper we prove that the norms on a large class of functions are comparable. The work is inspired by a paper by Astengo, Cowling, and Di Blasio \cite{Astengo2004}, who construct uniformly bounded representations for simple Lie groups of rank $1$. We formulate the problem in a much more general framework of groups acting on Möbius structures. In particular, all hyperbolic groups.
HarmonicAnalysisOnTheBoundaryOfHyperbolicGroups.pdf (1.01 Mo) Télécharger le fichier
hal-03963498 , version 1 (30-01-2023)
hal-03963498 , version 2 (31-01-2023)
hal-03963498 , version 3 (11-02-2023)
hal-03963498 , version 4 (21-02-2023)
  • HAL Id : hal-03963498 , version 1
Georg Alexander Gruetzner. Harmonic analysis on the boundary of hyperbolic groups. 2023. ⟨hal-03963498v1⟩
180 Consultations
69 Téléchargements
