Trivialisable control-affine systems revisited - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
The purpose of this paper is to explore the concept of trivial control systems, namely systems whose dynamics depends on the controls only. Trivial systems have been introduced and studied by Serres in the the context of control-nonlinear systems on the plane with a scalar control. In our work, we begin by proposing an extension of the notion of triviality to control-ane systems with arbitrary number of states and controls. Next, our rst result concerns two novel characterisations of trivial control-ane systems, one of them is based on the study of innitesimal symmetries and is thus geometric. Second, we derive a normal form of trivial control-ane systems whose Lie algebra of innitesimal symmetries possesses a transitive almost abelian Lie subalgebra. Third, we study and propose a characterisation of trivial control-ane systems on 3-dimensional manifolds with scalar control. In particular, we give a novel proof of the previous characterisation obtained by Serres. Our characterisation is based on the properties of two functional feedback invariants: the curvature (introduced by Agrachev) and the centro-ane curvature (used by Wilkens). Finally, we give several normal forms of control-ane systems, for which the curvature and the centro-ane curvature have special properties.
L'objectif de cet article est d'explorer le concept de système de contrôles trivial,c'est-à-dire un système dont la dynamique dépend uniquement des commandes. Les systèmes triviaux ont été introduits et étudiés par Serres dans le contexte des systèmes bidimensionnels et non-linéaires par rapport à un contrôle scalaire. Dans notre travail, nous commençons par proposer une extension de la notion de trivialité aux systèmes affines par rapport aux contrôles et avec un nombre arbitraire d'états et de contrôles. Ensuite, notre premier résultat concerne deux nouvelles caractérisations des systèmes affines triviaux, l'une d'entre elles est basée sur l'étude des symétries infinitésimales et est donc géométrique. Deuxièmement, nous donnons une forme normale pour les systèmes affines triviaux dont l'algèbre de Lie des symétries infinitésimales possède une sous-algèbre de Lie presque abélienne. Troisièmement, nous étudions et proposons une caractérisation des systèmes affines triviaux sur des variétés à $3$ dimensions et avec un contrôle scalaire. En particulier, nous donnons une nouvelle preuve de la caractérisation précédemment obtenue par Serres. Notre caractérisation est basée sur les propriétés de deux invariants fonctionnels du bouclage : la courbure (introduite par Agrachev) et la courbure centro-affine (utilisée par Wilkens). Enfin, nous donnons plusieurs formes normales de systèmes affine, pour lesquelles la courbure et la courbure centro-affine ont des propriétés particulières.
trivial_systems_tschmoderer_wrespondek.pdf (387.05 Ko) Télécharger le fichier
Licence : CC BY NC SA - Paternité - Pas d'utilisation commerciale - Partage selon les Conditions Initiales
hal-03971788 , version 1 (03-02-2023)
Timothée Schmoderer, Witold Respondek. Trivialisable control-affine systems revisited. 2023. ⟨hal-03971788⟩
47 Consultations
43 Téléchargements
