Visual Effects of Surface Tension on the Appearance of Wet Surfaces - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Book Sections Year : 2023
Some of the most interesting visual aspects of our environment often go unnoticed because of their familiarity. We are so much accustomed to them that we hardly pay attention to their intricacies, even less to our ability to rely on them in everyday behaviors. A convincing example is how water affects the appearance of surfaces, through both microscopic and macroscopic effects. Virtually everything changes: colors, shadows, gloss, geometry, etc., in ways that depend on the type of surface that is wet. Why is that so?
No file
Dates and versions
hal-03977621 , version 1 (07-02-2023)
Identifiers
  • HAL Id : hal-03977621 , version 1
Cite
Pascal Barla, Loic Lachiver, Gaël Guennebaud. Visual Effects of Surface Tension on the Appearance of Wet Surfaces. Lionel Simonot (Publication director). RADIOMETRY OF WET SURFACES - When Water Matters, 2023. ⟨hal-03977621⟩
41 View
0 Download
Share
