A layer potential approach to inverse problems in brain imaging - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
We study the inverse source (primary current) localisation problem using the electrical potential measured point-wise inside the head with stereo-ElectroEncephaloGraphy (sEEG), the electrical potential measured point-wise on the scalp with ElectroEncephaloGraphy (EEG) or the magnetic flux density measured point-wise outside the head with MagnetoEncephaloGraphy (MEG). We present a method that works on a wide range of models of primary currents, in particular we give details for primary currents that are assumed to be smooth vector-fields that are supported on and normally oriented to the grey/white matter interface. Irrespective of the data used we need to understand the transmission of the electric potential associated with a recovered source through the head hence we solve the cortical mapping problem. To ensure that the electric potential and normal currents are continuous in the head, the electric potential is expressed as a linear combination of double layer potentials and the magnetic flux density is expressed as a linear combination of single layer potentials. Numerically, we solve the problems on meshed surfaces of the grey/white matter interface, cortical surface, skull and scalp. A main feature of the numerical approach we take is that on the meshed surfaces we can compute the double and single layer potentials exactly and at arbitrary points. Because we study the transmission of the electric potential in head irrespective of the modality used, this enables the coupling of electric and magnetic data in the source recovery problem. We provide numerical examples of the source recovery and inverse cortical mapping using synthetic data.
A layer potential approach to inverse problems in brain imaging.pdf (6.17 Mo) Télécharger le fichier
hal-03977724 , version 1 (07-02-2023)
hal-03977724 , version 2 (20-12-2023)
  • HAL Id : hal-03977724 , version 1
Paul Asensio, J-M Badier, Juliette Leblond, Jean-Paul Marmorat, Masimba Nemaire. A layer potential approach to inverse problems in brain imaging. 2023. ⟨hal-03977724v1⟩
153 Consultations
67 Téléchargements
