Computing the Charlap-Coley-Robbins modular polynomials
Let E be an elliptic curve over a field K and L a prime.
There exists an elliptic curve E* related to E by an
isogeny (rational map that is also a group homomorphisms) of
degree L if and only Phi_Ll(X, j(E)) = 0, where
Phi_L(X, Y) is the traditional modular polynomial.
Moreover, the modular polynomial
gives the coefficients of E*, together with parameters needed to
build the isogeny explicitly. Since the traditional modular
polynomial has large coefficients, many families with smaller
coefficients can be used instead, as described by Elkies, Atkin and others.
In this work, we concentrate on the computation of the family of
modular polynomials introduced
by Charlap, Coley and Robbins. It has the advantage of giving directly
the coefficients of E* as roots of these polynomials. We review and
adapt the known algorithms to perform the computations of modular
polynomials. After describing the use of series computations, we
investigate fast algorithms using floating point numbers based on fast
numerical evaluation of Eisenstein series. We also explain how to use
isogeny volcanoes as an alternative.
Théorie des nombres [math.NT]
