A Higher-Order Indistinguishability Logic for Cryptographic Reasoning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
Adrien Koutsos
Joseph Lallemand
The field of cryptographic protocol verification in the computational model aims at obtaining formal security proofs of protocols. To facilitate writing such proofs, which are complex and hard to automate, Bana and Comon have proposed the Computationally Complete Symbolic Attacker (CCSA) approach, which is based on a first-order logic with a probabilistic computational semantics. Later, a meta-logic was built on top of the CCSA logic, to extend it with support for unbounded protocols and effective mechanisation. This metalogic was then implemented in the SQUIRREL prover. In this paper, we propose a careful redesign of the SQUIRREL logic, providing clean and robust foundations for its future development. We show in this way that the original meta-logic was both needlessly complex and too restrictive. Our new logic, using higher-order, avoids the indirect definition of the meta-logic on top of the CCSA logic, decouples the logic from the notion of protocol, and supports advanced generic reasoning and non-computable functions. We also equip it with generalised cryptographic rules allowing corruption. This theoretical work justifies our extension of SQUIRREL with higher-order reasoning, which we illustrate on case studies.
main (1).pdf (610.24 Ko) Télécharger le fichier
hal-03981949 , version 1 (14-02-2023)
hal-03981949 , version 2 (21-04-2023)
  • HAL Id : hal-03981949 , version 1
David Baelde, Adrien Koutsos, Joseph Lallemand. A Higher-Order Indistinguishability Logic for Cryptographic Reasoning. 2023. ⟨hal-03981949v1⟩
309 Consultations
235 Téléchargements
