AGOD-Grasp: an Automatically Generated Object Dataset for benchmarking and training robotic grasping algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
Robust robotic grasping of objects has broad industrial applications. The reliability of data-driven grasping methods is influenced by the variability of object shapes encountered during training. Most existing objects datasets suffer from human selection bias, lack variability, or are nonreproducible. This paper presents a physically reproducible 3Dprintable object dataset for training and evaluating grasping algorithms. It contains exact 3D meshes of 50 objects for simulation and printing purposes. The various objects in the dataset were found using the MAP-Elites algorithm, optimising the variability of objects according to two grasping metrics. We used a Variational AutoEncoder (VAE) as a generative model for voxelgrid object models, which were then converted to meshes and simplified using Volumetric Hierarchical Approximate Convex Decomposition (V-HACD). The dataset is publicly available online, and can be ordered from any 3dprinting service according to given specifications. We hope it will become a standard benchmarking dataset for the robotic grasping community.
HEAP_object_set_paper.pdf (2.03 Mo) Télécharger le fichier
hal-03983079 , version 1 (10-02-2023)
hal-03983079 , version 2 (03-03-2023)
  • HAL Id : hal-03983079 , version 1
Mihai Andries, Yoann Fleytoux, J.-B. Mouret, Serena Ivaldi. AGOD-Grasp: an Automatically Generated Object Dataset for benchmarking and training robotic grasping algorithms. 2020. ⟨hal-03983079v1⟩
98 Consultations
166 Téléchargements
