Reverse engineering language acquisition with child-centered long-form recordings - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Annual Review of Linguistics Année : 2022
Language use in everyday life can be studied using lightweight, wearable recorders that collect long-form recordings - that is, audio (including speech) over whole days. The hardware and software underlying this technique is increasingly accessible and inexpensive, and these data are revolutionizing the language acquisition field. We first place this technique into the broader context of the current ways of studying both the input being received by children and children’s own language production, laying out the main advantages and drawbacks of long-form recordings. We then go on to argue that a unique advantage of long-form recordings is that they can fuel realistic models of early language acquisition that use speech to represent children's input and/or to establish production benchmarks. To enable the field to make the most of this unique empirical and conceptual contribution, we outline what this reverse engineering approach from long-form recordings entails, why it is useful, and how to evaluate success.
_Marvin__Daylong_Data_in_Child_Language_Acqusition__Ann_Rev_Ling_.pdf"; filename*=UTF-8''_Marvin__Daylong_Data_in_Child_Language_Acqusition__Ann_Rev_Ling_.pdf (5.62 Mo) Télécharger le fichier
hal-03992325 , version 1 (05-12-2023)
Marvin Lavechin, Maureen De Seyssel, Lucas Gautheron, Emmanuel Dupoux, Alejandrina Cristia. Reverse engineering language acquisition with child-centered long-form recordings. Annual Review of Linguistics, 2022, 8, pp.389-407. ⟨10.1146/annurev-linguistics-031120-122120⟩. ⟨hal-03992325⟩
47 Consultations
11 Téléchargements
