A Kurdyka-Lojasiewicz property for stochastic optimization algorithms in a non-convex setting - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
Emilie Chouzenoux
Jean-Baptiste Fest
  • Fonction : Auteur
  • PersonId : 1159534
Audrey Repetti
  • Fonction : Auteur
  • PersonId : 1086960
Stochastic differentiable approximation schemes are widely used for solving high dimensional problems. Most of existing methods satisfy some desirable properties, including conditional descent inequalities, and almost sure (a.s.) convergence guarantees on the objective function, or on the involved gradient. However, for non-convex objective functions, a.s. convergence of the iterates, i.e., the stochastic process, to a critical point is usually not guaranteed, and remains an important challenge. In this article, we develop a framework to bridge the gap between descent-type inequalities and a.s. convergence of the associated stochastic process. Leveraging a novel Kurdyka-Łojasiewicz property, we show convergence guarantees of stochastic processes under mild assumptions on the objective function. We also provide examples of stochastic algorithms benefiting from the proposed framework and derive a.s. convergence guarantees on the iterates.
2302.06447.pdf (344.89 Ko) Télécharger le fichier
hal-03992655 , version 1 (16-02-2023)
Emilie Chouzenoux, Jean-Baptiste Fest, Audrey Repetti. A Kurdyka-Lojasiewicz property for stochastic optimization algorithms in a non-convex setting. 2023. ⟨hal-03992655⟩
27 Consultations
159 Téléchargements
