Randomly stacked open cylindrical shells as functional mechanical energy absorber - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Communications Materials Année : 2023
Structures with artificially engineered mechanical properties, often called mechanical meta- materials, are interesting for their tunable functionality. Various types of mechanical meta- materials have been proposed in the literature, designed to harness light or magnetic interactions, structural instabilities in slender or hollow structures, and contact friction. However, most of the designs are ideally engineered without any imperfections, in order to perform deterministically as programmed. Here, we study the mechanical performance of randomly stacked cylindrical shells, which act as a disordered mechanical metamaterial. Combining experiments and simulations, we demonstrate that the stacked shells can absorb and store mechanical energy upon compression by exploiting large deformation and relo- cation of shells, snap-fits, and friction. Although shells are oriented randomly, the system exhibits statistically robust mechanical performance controlled by friction and geometry. Our results demonstrate that the rearrangement of flexible components could yield versatile and predictive mechanical responses.
Sano_et_al-2023-Communications_Materials.pdf (1.69 Mo) Télécharger le fichier
FeaturedImage.pdf (1.17 Mo) Télécharger le fichier
Movie1_Phi270_Exp_vs_Sim.mp4 (41.98 Mo) Télécharger le fichier
Movie2_Phi350_Exp_vs_Sim.mp4 (29.44 Mo) Télécharger le fichier
Movie3_DifferentPhi_200_270_350.mp4 (21.18 Mo) Télécharger le fichier
Movie4_Phi310_mu0_035_10.mp4 (28.33 Mo) Télécharger le fichier
SupplementaryFile.pdf (884.32 Ko) Télécharger le fichier
Format : Figure, Image
Format : Vidéo
Format : Vidéo
Format : Vidéo
Format : Vidéo
Format : Autre
hal-03996830 , version 1 (20-02-2023)
hal-03996830 , version 2 (30-08-2023)
Tomohiko G Sano, Emile Hohnadel, Toshiyuki Kawata, Thibaut Métivet, Florence Bertails-Descoubes. Randomly stacked open cylindrical shells as functional mechanical energy absorber. Communications Materials, 2023, 4 (59), ⟨10.1038/s43246-023-00383-2⟩. ⟨hal-03996830v2⟩
99 Consultations
64 Téléchargements
