Construction and analysis of a HDG solution for the total-flux-formulation of the convected Helmholtz equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematics of Computation Année : 2023
We introduce a HDG method for the convected Helmholtz equation based on the total flux formulation, in which the vector unknown represents both diffusive and convective phenomena. This HDG method is constricted with the same interpolation degree for all the unknowns and a physically informed value for the penalization parameter is computed. A detailed analysis including local and global well-posedness, as well as a superconvergence result is carried out. We then provide numerical experiments to illustrate the theoretical results.
preprint_hdg_tot.pdf (976.27 Ko) Télécharger le fichier
hal-04006555 , version 1 (28-02-2023)
Hélène Barucq, Nathan Rouxelin, Sébastien Tordeux. Construction and analysis of a HDG solution for the total-flux-formulation of the convected Helmholtz equation. Mathematics of Computation, In press, pp.34. ⟨10.1090/mcom/3850⟩. ⟨hal-04006555⟩
102 Consultations
71 Téléchargements
