Direct Kinematic Singularities and Stability Analysis of Sagging Cable-driven Parallel Robots - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Robotics Année : 2023
Sagging cable-driven parallel robots (CDPRs) are often modeled by using the Irvine's model. We will show that their configurations may be unstable, and moreover, that assessing the stability of the robot with the Irvine's model cannot be done by checking the spectrum of a stiffness matrix associated with the platform motions. In this article, we show that the static configurations of the sagging CDPRs are local extrema of the functional describing the robot potential energy. For assessing the stability, it is then necessary to check two conditions: The Legendre–Clebsch and the Jacobi conditions, both well known in optimal control theory. We will also 1) prove that there is a link between some singularities of the CDPRs and the limits of stability and 2) show that singularities of the platform wrench system are not singularities of the geometric model of the sagging CDPRs, contrary to what happens in rigid-link parallel robotics. The stability prediction results are validated in simulation by cross-validating them by using a lumped model, for which the stability can be assessed by analyzing the spectrum of a reduced Hessian matrix of the potential energy.
TechReport_stab_saggingplanarCDPR.pdf (825.49 Ko) Télécharger le fichier
stab_saggingCDPR.pdf (1.64 Mo) Télécharger le fichier
Format : Autre
Licence : Domaine public
Commentaire : This technical report is associated with the paper [1]. It aims at giving the equations for the computation of the geometrico– static model equations of planar CDPRs based on the Irvine’s model, as well as the equations for their stability analysis. It ends with a case study. [1] S. Briot, J-P. Merlet. "Direct Kinematic Singularities and Stability Analysis of Sagging Cable-driven Parallel Robots". IEEE Transactions on Robotics
hal-04007182 , version 1 (04-03-2023)
  • HAL Id : hal-04007182 , version 1
Sébastien Briot, Jean-Pierre Merlet. Direct Kinematic Singularities and Stability Analysis of Sagging Cable-driven Parallel Robots. IEEE Transactions on Robotics, 2023, 39 (3), pp.2240-2254. ⟨hal-04007182⟩
65 Consultations
101 Téléchargements
