A neural field model for ignition and propagation of cortical spreading depression - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
Un modèle de champ neuronal pour l'allumage et la propagation de la dépression corticale propagée
We propose a new neural field model for migraine-related cortical spreading depression (CSD). The model follows the Wilson-Cowan-Amari formalism. It is based on an excitatory-inhibitory neuron population pair which is coupled to a potassium concentration variable. This model is spatially extended to a cortical layer. Therefore, it can model both the ignition and propagation of CSD. It controls the propagation speed via connection weights and contribution weight of each population activity to the potassium accumulation in the extracellular matrix. The simulation results regarding the propagation speed are in coherence with the experiment results provided in Chever et al. (2021).
spreadingDepression.pdf (781.51 Ko) Télécharger le fichier
Licence : CC BY - Paternité
hal-04008117 , version 1 (28-02-2023)
Paternité
  • HAL Id : hal-04008117 , version 1
E Baspinar, D Avitabile, M Desroches, M Mantegazza. A neural field model for ignition and propagation of cortical spreading depression. 2023. ⟨hal-04008117⟩
127 Consultations
94 Téléchargements
