A low-rank tensor method for parameterized linear fluid-structure interaction problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This talk will present a low-rank tensor method for parameterized linear fluid-structure interaction problems. In this work, the fluid is governed by the incompressible Stokes equations, and we assume a thick-walled solid model. In order to reduce the computational cost associated with the coupled problem, we develop a low-rank tensor method based on the low-rank Generalized Minimal Residual method. This one is then employed in an uncertainty quantification task to perform a large number of simulations. The preliminary results show the significant reduction of the computational cost provided by the proposed method.
CMBE21TemplateAbstract.pdf (171.11 Ko) Télécharger le fichier
hal-04010551 , version 1 (01-03-2023)
  • HAL Id : hal-04010551 , version 1
Sébastien Riffaud, Miguel Angel Fernández, Damiano Lombardi. A low-rank tensor method for parameterized linear fluid-structure interaction problems. CMBE 2022 - 7th International Conference on Computational and Mathematical Biomedical Engineering, Jun 2022, Milan, Italy. ⟨hal-04010551⟩
24 Consultations
11 Téléchargements
